Hamburg Flyers R/C Club
Public Section => For Sale => General Discussion => Airplanes => Topic started by: Gary Whitlark on July 28, 2022, 06:20:43 AM
Title: (#26) UMX Yak 54 3D BNF with AS3X, 430mm Item No. E-flite - EFLU3550 w/lipo
Post by: Gary Whitlark on July 28, 2022, 06:20:43 AM
Asking: $80 each, 2 available
https://youtu.be/RBAyc71kIW0
Key Features
Box serves as an airplane case.
No assembly required
Exclusive AS3X® stabilization technology
Multiple flight modes that make 3D easy
Feather-light, carbon-reinforced foam airframe
Side-Force Generators for improved knife-edge flight
Potent 8.5mm coreless motor
Spektrum DSMX® receiver
Spektrum long-throw performance linear servos
Stunning red and silver trim scheme
Carbon fiber landing gear with simulated wheel pants
Needed To Complete
Full-range, 6+ channel DSMX®/DSM2® transmitter
150mAh 1S 3.7V 45C LiPo flight battery
1S LiPo charger
Overview
With a flying weight of barely over an ounce (36 grams), the compact UMX™ Yak 54 3D ultra-micro is small enough and light enough to be flown just about anywhere. But what really sets it apart is its specially tuned AS3X® stabilization system. This exclusive technology makes it easy for sports pilots to discover the fun of hovering and harriers without sacrificing any of the agility an expert 3D pilot demands.
Specially Tuned AS3X® Receiver Makes 3D Easy
The AS3X® (Artificial Stabilization - 3-aXis) technology in the model's receiver makes it easy to discover the fun of 3D aerobatics without feeling frustrated. Using a unique combination of sensors and software, it works behind the scenes to make slow-speed and knife-edge maneuvers feel incredibly stable without limiting the aircraft's agility or interfering with your control. The plane simply stays in whatever attitude you want without making you struggle to keep it there.
The receiver also features five pre-programmed flight modes - three default modes that are active out of the box and two alternate modes you can activate later. Each has different AS3X® stability settings tailored for your skill level or the 3D maneuver you want to try.
Default Modes
General Flight Mode
Heading hold in roll-axis for a locked-in feel.
Standard AS3X® Mode
Tuned for the expert 3D pilot but great for flying pattern aerobatics, too.
Hover Assist Mode
Aggressive heading hold in roll, yaw, and pitch so it's easier to enter and maintain a hover.
Alternate Modes
Knife-Edge Assist Mode
Heading hold settings for roll, yaw, and pitch that make it easy to try knife-edge maneuvers.
Torque Roll Assist Mode
Aggressive heading hold settings for yaw and pitch that make torque rolls easier.
Flight-Ready Out of the Box
No assembly is required. The model comes with the motor, Receiver/ESC, and servos already installed. All you have to do is charge a battery, bind it to a compatible DSMX/DSM2® transmitter and fly. An E-flite® 150mAh 1S 3.7V 45C LiPo battery is recommended for best performance.*
Feather-Light, Carbon-Reinforced Airframe
Carbon fiber rods brace the wings so you can enjoy the outstanding power-to-weight performance and still have the rigidity necessary for crisp control response. The model also features carbon fiber landing gear with wheel pants.
Built-In Side Force Generators
Side Force Generators attached to the wing tips boost rudder authority in knife-edge flight so you can fly tighter knife-edge loops.
*Battery, transmitter, and charger are all sold separately.
Product Specifications
Approximate Assembly Time   No assembly is required
Approximate Flight Time   4-5 minutes
Flaps   No
Completion Level   Bind-N-Fly Basic
Recommended Motor Battery   3.7V 1S 150mAh 45C LiPo
Power Type   Electric
Skill Level   Level 2
Wingspan   16.9 in (430mm)
Motor Size   8.5mm x 23mm brushed
Product Length   19.6in (497mm)
Speed Control   Included
Minimum Required Radio   6 Channel
Technology   AS3X
Receiver   Included
