Hamburg Flyers R/C Club
Public Section => For Sale => General Discussion => Radio Equipment => Topic started by: Gary Whitlark on July 29, 2022, 02:06:14 PM
Title: (#42) Hitec SERVO Micro HS-81 (only 1)
Post by: Gary Whitlark on July 29, 2022, 02:06:14 PM
Product Description
You get two choices with Hitec’s most popular servo the HS-81, resin or metal gears. The HS-81 offers a delicate balance between speed and torque, a popular servo for smaller airplanes, helicopters, boats, cars, and trucks.
Features
Top Selling Micro Servo
Strong Three-Pole Ferrite Motor
Durable Nylon Gears
Accessories
Nylon Gear Set | Link |
Plastic Case Set | Link |
Applicable Horns
HS-81 Servo Specifications
Performance Specifications
Operating Voltage Range (Volts DC)   4.8V ~ 6.0V
Speed (Second @ 60°)   0.11 ~ 0.09
Maximum Torque Range oz. / in.   36 ~ 42
Maximum Torque Range kg. / cm.   2.6 ~ 3.0
Current Draw at Idle   8.8 mA
No Load Operating Current Draw   280 mA
Stall Current Draw   1,500 mA
Dead Band Width   8 µs
Physical Specifications
Dimensions (Inches)   1.17 x 0.47 x 1.16
Dimensions (Metric)   29.8 x 12.0 x 29.6
Weight (Ounces)   0.58
Weight (Gram)   16.6
Circuit Type   HT7003 Analog SMT
Motor Type   3 Pole Metal Brush Ferrite
Gear Material   Nylon
Bearing Type   None
Output Shaft (type / Ømm)   Standard 24
Case Material   Plastic
Dust / Water Resistance   N / A
Connector Gauge (AWG) / Strand Count   28 / 20
eBay shipped $13.99.   Ask price is $10
