![](https://hamburgflyers.org/forum/index.php?PHPSESSID=24837a58f546ca37c3fdc38f515fe420&action=dlattach;topic=507.0;attach=483;image)
Extra 300 96" wingspan ARF ($2200 firm) My favorite currently.
Weight no fuel with batteries and receiver (TBD) After ordering the prop,
If separated estimates or current new reference prices:
DA60 Extra 300 (Airframe looks unflown no stains $700)
DA 60 Engine (new $689 + shipping)
ENGINE 60DA Specifications:
Displacement: 3.7 ci (60.5cc)
Weight: 3.1 lbs (1.41 kilos)
Typical RPM Range: 1200-7200
Warranty: 3 Year
Bolt Circle: 30mm
Prop Bolt: (4) 5mm
Features
Desert Aircraft, auto advance, electronic ignition.
Exclusive Desert Aircraft designed cylinders, pistons, and crankshaft.
Aerobatic power curve.
Recommended Props
2-Blades
22x12
23x10
24x8 Thrust (40.5 lbs)
24x9* *Most recommended 90" 3D prop Thrust (42 lbs)
Muffler Open Slimline style Resonator Can dual port (new $65 + shipping)
Spinner Miracle 4.5" ($55 new)
Prop Vess 26a" ($48 new) Oversized for the motor. Prop normal for 70 - 90 size engines. No pitch rating from the manufacturer. Estimate pitch 8.
((Recommended Prop 60DA Canister Extra 3D Vess 24B carbon and wood or Falcon Carbon 24x9 most thrust and low engine noise.))
From the Falcon website, the 24x9 makes 18.4kg thrust and the 24x8 makes 19.1 kg.
Receiver batteries (2x) New unused, Zippy compact LiPoFe4 2100 mah each. ($20 x 2)
Ignition 2 2 cell lipo Batteries (TBD new needed)
Pull-Pull Aluminum long arm rudder.
Heavy duty switches and external charge ports x3.
Fuel tank (size ?), filler nipple, and gas line.
Double plate clevis and ball joints on all control surfaces.
Servos: 2 Ailerons, 2 elevators, 1 Rudder, 1 ignition, and 1 choke.
(5) Hitec HS-9955TG Digital Tungsten Gear Coreless (Discontinued new $110 ea., used eBay $50 ea.)
(2) TBD SERVOS - Switch operations (est. $15 used like new appearance)
Spectrum NEW AR12120 2.4G12 Channel Power Safe Receiver for SPMAR12120 with 4 Satellites ($88)
Smart-Fly Power Expander Competition 12 (new $159.95, Asking $120) Pros tell me this is overkill for this sized airplane. I may move to my 120" Carden.
Smart-Fly Ignition cutoff ($50 new)
Heavy-duty servo extensions
"RC Armor" wing bags (New $150, I am asking for $100)
