Asking: $80 as package TX, RX, TX - Lipo, DSSS module, and Case.
Separated: Radio $50, DSSS Module $15, Case $15, RX $10, TX-Lipo $10.
Developed by a team of RC hardware and software gurus, the Turnigy 9XR set out to upset the 'big boys' in the industry by bringing to market a radio that is packed full of features at an extremely affordable price. Now we have the Turnigy 9XR PRO, the next revolution in radio systems!
True to the ethos of the original, the 9XR PRO still offers great value but we have completely overhauled this radio to make it even more powerful based on customer feedback. Working with a crack team of R/C specialists, we've made additions such as a USB and SD card slot, voice and vibration feedback as well as making this radio telemetry capable.
You're unlikely to 'outgrow' this radio anytime soon. The new SD Card is used to store your custom sound files, telemetry data logging, model storage and firmware updates. If you're techy this radio will keep you busy unlocking new features, but if you just want to 'go out and fly', this radio is easier to program than ever!
The specs "speak" for themselves, the People's radio just got even better!
9XR Pro Added Features:
• ARM version of er9x radio firmware with EESKYPE simulater GUI support
• 24 channel support
• 48 free mixes
• Expo, Triple rates, Curves settings
• Voice alerts
• Telemetry display
• Atmel SAM3S ARM Cortex M3 , 32 bit Micro-controller , 512K flash , 64Kb of SRAM
• 4Mb EEprom for 30+ model storage
• Micro SD card (Included)
• Mini USB port, for access to SD card files and radio programing
• 1/2 Watt Audio Amplifier with digital control.
• RS232 Serial Port for External telemetry connection through Futaba trainer jack. (for DHT ,DXT)
• Logic level Serial Port for external Blue Tooth modules (HC-06,RN42)
• Dimable LED Back light
• Haptic Buzzer (pager vibrator) for trim center alert and alarm notifications
• Real "Tact" switches on menu keys, give positive feedback indication
• Built in bootloader. (Firmware can be updated in less than 15 seconds!)
• Full built-in Telemetry support for the latest RF modules. New DSM modules coming soon.
• Speaker and headphone outputs
• Ball Bearing gimbals
• Digital Trims
• Assignable Switches
• Freely Assignable Channel Mixes
• Graphical Dual Rate, Sub trims, travel adjust and Exponential
• Supports Heli/Aero/Glider and custom Model Types
• Programming templates based on model type
• Supports M1, M2, M3, M4 stick modes
• 128 x 64 backlit Liquid Crystal Display
• Built in JR & Futaba Trainer Ports
• JR Form Factor RF Modules (ORX Dsm2, ORX Open LRS 433Mhz etc)
• Programmable warnings
• 1.5Amp, 5V main switching regulator, with wide input voltage (6.5 - 30V) (uses 3S lipo connection same as 9XR)
• Rotary encoder with push switch port (rotary encoder not included - user upgrade)
• Support for 6-way switch and more 3 way switches. (User upgrade)
• And so much more!!
A full set of user manuals and user videos are available to help learn how to use this powerful radio. Online support and user forums available at:
www.turnigy9xr.comSpec:
Channnel: Up to 24 supported
Display: 128*64LCD (dimmable Backlit)
Support Type: Heli/Acro/Glid/Custom
Model Memory: 30+
Stick modes: 1, 2, 3, 4
Encoder type: ppm/pcm
Module Interface: JR Compatible (See Related Items Below)
Simulator Interface: Yes (JR & Futaba)
Buzzer/Speaker: Yes
Battery Compartment: 112 x 44 x 27mm
Weight (less battery & Rf Module): 723g
Required:
3S Lipo Battery
RF Module
Included:
Turnigy 9XR PRO Transmitter (Mode 2 – Throttle on Left Stick)
Quick Start guide
*Note: This version is supplied without an RF Module, please order the relevant RF module from the accessories list below.
**Note: To use the telemetry with FrSky modules the optional plug in cable is required.
Turnigy DSSS 2.4Ghz Transmitter Module For 9XR / 9XR Pro (JR Configuration)
Receiver FS-R9A
CASE:
https://youtu.be/Kx-yenfF8XU Lipo: Turnigy 9XR Safety Protected 2200mAh 3S 1.5C Transmitter Pack
